How many APs the AP103 can control using the virtual controller??
How many APs the IAP103 can control using the virtual controller??
Frequent Contributor II
Re: How many APs the AP103 can control using the virtual controller??
From what I know there isn't limits on number of IAP103 in a cluster, like IAP105 and other IAPs. You can deploy how many IAP103 you want in your cluster.
The only thing is taht you must not have IAP93 in your cluster, otherwise you are limit to 16 IAP for cluster.
[If you found my post helpful, please give kudos]
Massimo Gallina
Telecommunications engineer - ACMP2013
This is true...there are no limits on the AP103.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
