How to forbideHow to ban android, iphone and ipad device on IAP (92-93-102-103) Aruba ?
Hi all,
I need you help, i installed 19 aruba IAP, but now i need to ban all personnal device (smartphone... android, iphone and ipad).
Do you know how can i performed this prohibition?
Thank you in advance
Chabin972
Re: How to forbideHow to ban android, iphone and ipad device on IAP (92-93-102-103) Aruba ?
How will you be determining what is personally owned?
Tim Cappalli | Aruba Security
Hello Cappalli,
In my company, we would like ban all mobile phone personnal or professionnal. The wireless is only for laptop and specific device motorolla (ex: MC3091 on windows CE)
It's for this reason I want to block iPhone and android system. How can I make it? Is it possible to block the device compared his model?
Thank you in advance.
Best regards
Chabin972
chabin_972,
If you don't have an external radius server like clearpass that identifies device OS types it could be difficult.  Please see the article here: http://community.arubanetworks.com/t5/Controller-less-WLANs/DHCP-FINGERPRINTING-WITH-Aruba-Instant/ta-p/183272
Hi Colin Joseph,
Thank you for your reply.
I will close this request because I don't use radius.
Thanks again
