Occasional Contributor I
How to get different wired port setups on APs in cluster
I have two 205H in a cluster, one is mesh portal, the other is mesh point.
They have 4 wired ports each, and i need different wired port setup on the portal and the point.
But wired configuration seems to be global for the instant cluster, i can't find a way to configure them independently?
