How to integrate an AP205 with an existing mesh network
  • 1.  How to integrate an AP205 with an existing mesh network
    Posted Jan 14, 2016 10:54 AM
    I have an AP205 that I am trying to join to my existing mesh network, but the AP will never come back up once I have initially provisioned it. I am convinced that it is related to a setting in my controller but I am not sure what needs to be adjusted. The controller is running ArubaOS 6.4.3.4, and the AP is a converted IAP.
  • 2.  RE: How to integrate an AP205 with an existing mesh network
    Posted Jan 14, 2016 11:03 AM
    The existing the mesh setup is configured through the Aruba Controller ?
    If it is then the new AP needs to be converted back to Campus AP and then in the controller you need make it a Mesh Point if you already have a Mesh Portal.
    But you need to make sure that both APs are in line of sight so they can form the Mesh link
