Frequent Contributor II
How to stop IAP Cluster with IAP225 attempting to authenticate all the time
Hello
I have a IAP Cluster with a mesh AP225 on a completely separate network with internet access and somehow the IAP-225 acting a virtual controller is all the time trying to authenticate to one my controllers connected on a DMZ which I use for RAP access to be converted to RAP.
It sounds during one my my tests, this IAP took the controller IP address and is sending 3-4 authentications/sec to my controller. I don't see anything on the configuration related to this.
This is the output from the log:
ec 10 08:18:21 cli[2994]: <341098> <WARN> |AP 94:b4:0f:c0:47:70@192.168.1.10 cli| recv_convert_ap: Convert AP url-, mode-1, master-X.X.X.10.
Dec 10 08:18:21 cli[2994]: <341005> <ERRS> |AP 94:b4:0f:c0:47:70@192.168.1.10 cli| VPN setup pending
Dec 10 08:48:35 cli[2994]: <341098> <WARN> |AP 94:b4:0f:c0:47:70@192.168.1.10 cli| recv_convert_ap: Convert AP url-, mode-1, master-X.X.X.10.
Dec 10 08:48:35 cli[2994]: <341005> <ERRS> |AP 94:b4:0f:c0:47:70@192.168.1.10 cli| VPN setup pending
Dec 10 09:17:50 cli[2994]: <341098> <WARN> |AP 94:b4:0f:c0:47:70@192.168.1.10 cli| recv_convert_ap: Convert AP url-, mode-1, master-X.X.X.10.
Dec 10 09:17:50 cli[2994]: <341005> <ERRS> |AP 94:b4:0f:c0:47:70@192.168.1.10 cli| VPN setup pending
Dec 10 09:48:04 cli[2994]: <341098> <WARN> |AP 94:b4:0f:c0:47:70@192.168.1.10 cli| recv_convert_ap: Convert AP url-, mode-1, master-X.X.X.10.
Dec 10 09:48:04 cli[2994]: <341005> <ERRS> |AP 94:b4:0f:c0:47:70@192.168.1.10 cli| VPN setup pending
Dec 10 10:18:19 cli[2994]: <341098> <WARN> |AP 94:b4:0f:c0:47:70@192.168.1.10 cli| recv_convert_ap: Convert AP url-, mode-1, master-X.X.X.10.
Dec 10 10:18:19 cli[2994]: <341005> <ERRS> |AP 94:b4:0f:c0:47:70@192.168.1.10 cli| VPN setup pending
Dec 10 10:44:16 cli[2994]: <341108> <ERRS> |AP 94:b4:0f:c0:47:70@192.168.1.10 cli| sess_sid_type_get: 310 invalid session client-192.168.1.8 sid-xfLOU45tv0KpU0UXNnIr.
Dec 10 10:48:34 cli[2994]: <341098> <WARN> |AP 94:b4:0f:c0:47:70@192.168.1.10 cli| recv_convert_ap: Convert AP url-, mode-1, master-X.X.X10.
Dec 10 10:48:34 cli[2994]: <341005> <ERRS> |AP 94:b4:0f:c0:47:70@192.168.1.10 cli| VPN setup pending
How can I stop this IAP to send all this traffic?  I tried several times to wipe the AP and still working like that.
Re: How to stop IAP Cluster with IAP225 attempting to authenticate all the time
Do you have a provisioning rule tied to it in Activate?
Tim Cappalli | Aruba Security
I've checked this several times and this IAP devices is on my  activate database without any provisioning rule although looking in detail I see it as RAP Mode
This guy is like a little DDOS and I had to put a rule on my internet firewall to stop this traffic
Guess what.... I have a nice default rule in activate
Tim, thank you to guide me to the right path. it was driving me crazy and I believe this issue has been causing some other problems with RAPs using the same egress access.
Now I see the endpoint on activate as IAP VC
