How to upgrade IAP Mesh Deployment
  • 1.  How to upgrade IAP Mesh Deployment
    Posted Jan 04, 2016 07:55 AM
    Hello Everyone and Happy New Year.
    I have a IAP cluster with the VC master acting as Mesh Portal and another IAP as Mess Point with AP225s. If I upgrade the cluster from the web gui, I always have problems with the Mess Point IAP which I have to do a factory default, deactivate extended SSID and re-create the Mesh configuration re-connecting both IAPs on the same switch which creates a very disruptive proccess.
    In order to use Mesh with AP225 I use Early Availability firmeware releases, is there any specific method to upgrade all the access points without startign from starting from scrath?
  • 2.  RE: How to upgrade IAP Mesh Deployment
    Posted Jan 04, 2016 08:36 AM
    What error do you get ?
    Is IAP225 patched through the E1 by any chance ?
    How healthy is the mesh link ? You can run the show AP mesh link to see the cost and the RSSI
    Pardon typos sent from Mobile
  • 3.  RE: How to upgrade IAP Mesh Deployment
    Posted Jan 04, 2016 08:55 AM
    Hi Victor,
    Basically the Mesh setup is broken. It seems the AP running as Mesh Point doesn't take and reboot with the new image.
    The Mesh portal is connected to a wired Internet connection using E0.
    Here yu have the output for the mesh link
    94:b4:0f:c0:47:70# sho ap mesh link
    Neighbor list
    MAC                Portal             Channel  Age  Hops  Cost  Relation                 Flags  RSSI  Rate Tx/Rx  A-Req  A-Resp  A-Fail  HT-Details     Cluster ID
    94:b4:0f:84:6c:30  94:b4:0f:84:77:11  52E      0    1     1.00  C 9d:0h:29m:0s           VLK    29    260/520     1      1       0       VHT-80MHz-3ss  6b164eb1e39bc37398cd55549b87b27
  • 4.  RE: How to upgrade IAP Mesh Deployment
    Posted Jan 04, 2016 09:20 AM
    I recommend that you disable 80 Mhz support under RF > ARM
  • 5.  RE: How to upgrade IAP Mesh Deployment
    Posted Jan 04, 2016 10:14 AM
    AP acting as mesh port portal is connected using E0, the one working as mesh point is not using any LAN port just serving wireless clients.
    In previous versions I faced so many problems with 80Mhz with the mesh configuration, with the 6.4.3.4-4.2.1.0 works great and specially in a multinant enviroment with the 2.4Ghz Band overutilized. The issue is during the upgrade proccess,  do you know if I have a way to upgrade the mesh point first and then the portal one?. If I have the same issue in production I won't be able to operate the system in real world. I target the feature as backup buildings using a fast connection over wireless
  • 6.  RE: How to upgrade IAP Mesh Deployment
    Posted Jan 05, 2016 04:22 AM
    When trying to upgrade each IAP individually I realized I couldn't access the Mesh Point via SSH from either a client connected on the LAN or Mesh Portal AP. Checking the configuration on the Mesh Point I had E0 Bridging deactivated. After enabling bidging on E0 I was able to upgrade the cluster from the WEB GUI without losing the configuration
