Contributor I
How to upgrade an IAP 115 using the cli
How do I upgrade system firmware using the CLI?
Re: How to upgrade an IAP 115 using the cli
Upgrading an Image Using CLI
To upgrade an image using a HTTP, TFTP, or FTP URL:
(Instant Access Point)# upgrade-image <ftp/tftp/http-URL>
To upgrade an image without rebooting the IAP:
(Instant Access Point)# upgrade-image2-no-reboot <ftp/tftp/http-URL>
To view the upgrade information:
(Instant Access Point)# show upgrade info
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Contributor I
Thanks Seth - this worked great!  Tftp was taking too long so I installed an Apache http server and it was able to upgrade pretty quickly after that.  The Internet connection at this location is not very good and it would fail to upgrade when using the GUI.
 Can i use the same commands for an ap225? I'm adding an ap225 to a virtual controller (ap135).
Yes.
Will the cmd work in apboot mode on a IAP 105? If not, how to upgrade if no DHCP server and not joining to cluster?
