Last login: Tue Dec 10 13:35:50 on ttys000
Shaines-MacBook-Air:~ Shaine$ ssh aruba@10.116.5.20
^C
aruba@10.116.5.20's password:
Launching IAP CLI...
PES-MDF-Room22# show airgroup
airgroup
airgroupservice
PES-MDF-Room22# show airgroup server
AirGroup Servers
MAC IP Host Name Service VLAN Wired/Wireless AP-Mac Update no/Hash
Num Servers:0
PES-MDF-Room22# show airgroup status
AirGroup Feature
Status
Enabled
AirGroup Multi Swarm
Status
Disabled
AirGroup Guest Multicast
Status
Disabled
CPPM Parameters
Parameter Value
CPPM Enforce Registration Disabled
CPPM Server query interval 0 Seconds
CPPM Server dead time 100 Seconds
AirGroup Service Information
Service Status
airplay Enabled
airprint Enabled
PES-MDF-Room22# show airgroup clients
% Parse error
PES-MDF-Room22#
AT AT command to Cellular modems; Format: AT "<at-cmd>"
a-channel static 5 GHz channel and power... set it to 0 for ARM assigned
a-external-antenna
aaa
apply
clear
clear-cert
clock System time
commit
configure Configuration commands
connect-support
convert-aos-ap
copy Copy files
debug Debugging information
debug-amp-audit
debug-amp-login
debug-amp-logout
debug-amp-stat
debug-amp-state
debug-ap-rx-pkts
debug-athena-server
debug-election-statistics
debug-image-server-freq
debug-image-server-sync
debug-image-sync-request
debug-master-beacon
debug-mobility
debug-uplink-fail-holding-time
disconnect-support
disconnect-user Disconnect user - logout and deauthenticate user
download-cert
enable
enet0-bridging
g-channel static 2.4 GHz channel and power... set it to 0 for ARM assigned
g-external-antenna
generate_gmon_output
get-sysctl
help System help
hostname System name
ids-reclassify
ip-address IP address
logout Exit the CLI
mesh-ldart-disable
no Delete command
pcap
ping Send ICMP echo packets to the specified IP address
process Process information
reload Restart the AP
remove-blacklist-client
set-sysctl
show Show commands
ssh
ssh-stop
support Engineering debug commands
swarm-mode
switch-partition-reboot
test
trace
trace-filter
traceroute Trace route to the specified IP address
upgrade-image
upgrade-image2
upgrade-image2-no-reboot
uplink-vlan
wifi0-mode
wifi1-mode
write Write running configuration to memory or terminal
cache
cppm
cppm-entry
cache
cppm
cppm-entry
servers
status Status
users
vlan VLAN information
PES-MDF-Room22# show airgroup users
AirGroup Users
MAC IP Host Name VLAN Wired/Wireless Role Username AP-Mac Query/Resp
90:b9:31:f2:c2:a4 0.0.0.0 3333 Wireless WSD3-Guest 24:de:c6:c3:e6:79 0/0
Num Users:1
PES-MDF-Room22# show version
ArubaOS (MODEL: 105), Version 6.2.1.0-3.4.0.4
Website: http://www.arubanetworks.com
Copyright (c) 2002-2013, Aruba Networks, Inc.
Compiled on 2013-11-15 at 05:14:03 PST (build 40899) by p4build
AP uptime is 1 week 18 hours 54 minutes 13 seconds
Reboot Time and Cause: AP rebooted Tue Dec 3 15:40:14 UTC 2013; User Reboot
PES-MDF-Room22#
