I'm trying to add an IAP to Airwave, but is not connecting
I configured my IAP with the Airwave IP and Organization name and passphrase but when cheking my Airwave I don't see any new APs. I test reachability between networks and it is ok. Do I have to configure something in the Airwave?
Re: I'm trying to add an IAP to Airwave, but is not connecting
What type of IAP ?
Version of OS on the IAP ?
Version of Airwave ?
Are you allowing port 443 between the IAP and Airwave ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Hi this is the device I have:
W-AP115
6.3.1.1-4.0.0.1_41049
AIRWAVE 8.0
did you load a backup from another IAP into this IAP-115?
If so, change a value in the virtual-controller-key.
for example
FROM: virtual-controller-key 21424572abc3237342def23523de
TO: virtual-controller-key 21424572abc3237342def23523f
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
I have another IAP the same version and is working fine. This IAP is a new one. I'm not seen connection attemps to AW from this AP. Please check the attached file.
Rgds,
EH
Trusted Contributor I
you seem to have one IAP in airwave which you first have to approve.
then the second, is it in the same cluster or different?
