I want to configure mesh on IAP105. help me please
help me
i have the IAP105   2 units
i want to configure mesh portal and mesh point
How do i configure
Re: I want to configure mesh on IAP105. help me please
If you update to the lastest firmware on both, Mesh should be enabled automatically.
yes i upgrade firmware laster version 6.1.2.3-2.0.0.1_31127
Mesh should work by default.  What are you trying to do?
Hi Wanasans, I have the same setup, 2 IAP-105, same firmware and followed the User Guide to the letter, first connected the APs to a DHCP server, they showed up having the mesh portal role, after this we disconnected one of the APs and connected again, it never shows in the VC again as it should (as a Mesh Point).
If you were able to make it work please post it here, thanks
Are you saying that you disconnected it from the wired network and then connected it to the wired network again, OR did you just provide power so that it could see the other access point?
Just provided power, they should have showed up but did not
Today I upgraded the two IAP-105 to 6.1.2.3-2.0.0.2_31127, and I can´t make them work with mesh, I started all over after upgrading firmware, connected the IAPs, made a new WLAN, diconnected one of them (power and network) and reconnected power, this mesh point should be seen in the VC under Access Point, nothing happens, I´ve cheched if there´s any configuration regarding mesh in the VC GUI but I don´t find any, please if anyone has made this setup work maybe can point us to where the problem is, thanks in advance
it works ok for me, can you attcach the result (goto 'support' tab and run command 'AP Tech Support Dump')?
Hi hlv,
Attached are the outputs first with both APs connected to the switch and after one of the APs was disconnected (data only)
