IAP-103 + IAP-105 cluster reboot loop
Hello!
Could you please help to analyze, we have a cluster from six APs - mixed IAP-103 and IAP-105.  Software version - everywhere 6.4.4.8-4.2.4.6.
And we are facing reboot loop on all APs with service impact during reboot period (again and again, all APs):
Reboot Information
Reboot caused by kernel page fault at virtual address 003c0004, epc == 801c5b70, ra == c034efd4
Reboot Information
Reboot caused by kernel page fault at virtual address 001a0004, epc == 801c5b70, ra == c0342874
How can we check, what this reboot reason should mean?
Thanks a lot in advance!
Re: IAP-103 + IAP-105 cluster reboot loop
And "show ap debug crash-info" we have:
https://pastebin.com/YUZ5XTm3
We have the same problem. Network sysadmin changed (attached) attached master AP role to another AP which was less loaded by system resources
Zabber can you do the same but choose 105 model AP to make it master and report results?
