IAP 103 RADIO Inactif
Dear All,
i upgrade my IAP 103 into InstantOS 6.4.2.0-4.1 . the problem is that the RADIO are inactive. what can be the probleme
Best Regards.
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: IAP 103 RADIO Inactif
What is the regulatory domain?
My regularity domain is DZ (algeria) , and i think that the probleme is with that , i will see with my custumer.
Raouf CHAHBOUNE
Occasional Contributor I
I have the same problem. When I access a new IAP205 and choose Algeria in the Coutry Code Window, the radio goes down and can't access the device until default config reset. Did you find a solution ?
Yes ,now the solution is simply to reset you IAP  from console or from the reset button , and next  you reconfigure you IAP using another Regularitory domain.
Raouf CHAHBOUNE
