IAP-103 at home
Airheads - I have an IAP-103 at home, and it works great, except in the corner of the house.  I purchased what I thought was another IAP-103 on ebay, but I think it may actually be an AP-103.   Can my existing IAP control the AP?   What options do I have?
My apologies if this question is in the wrong place
Thanks!
Re: IAP-103 at home
You can either purchase a controller, try to return the AP-103 or try to sell it on eBay.
Sent from Nine
Tim Cappalli | Aruba Security
Occasional Contributor I
Re: IAP-103 at home
developer testing comments0
#AirheadsMobile
Re: IAP-103 at home
comment testing0
#AirheadsMobile
Re: IAP-103 at home
test #AirheadsMobile
Re: IAP-103 at home
testtt
#AirheadsMobile
Re: IAP-103 at home
Aruba Sensor, a small, dual-band 802.11n client radio and a Bluetooth Low Energy (BLE) radio, makes it easy for IT to turn a mobile engagement proof-of-concept into a full-out, multi-location deployment by pulling beacon data into one centralized location.
The Aruba Sensor plugs directly into an AC outlet and can hear other Aruba Beacons within a 25-meter range and reports relevant data over Wi-Fi to the cloud-based platform
#AirheadsMobile
Re: IAP-103 at home
eee
#AirheadsMobile
Re: IAP-103 at home
test
#AirheadsMobile
Re: IAP-103 at home
anupam testing #AirheadsMobile
