- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
IAP-103 will not join cluster
10-01-2014 11:49 AM
Very odd situation here.
IAP-103 deployment of 23 APs, firmware of the VC 4.1.0.1, all of other APs factory defaulted and running 4.1.0.0 (shipped firmware).
Network installed, VC connected and up, then remaining 22 APs connected,
Total of 22 APs show up on the VC but not the last AP.
Running "show log system"
shows the following
********************************************************************************************************* 10/1/2014 12:56:40 PM Target: 9c:1c:12:cc:af:a8 Command: show log system ********************************************************************************************************* Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.23, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.28, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.17, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.25, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.37, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.33, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.27, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.31, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.20, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.35, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.29, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.19, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.36, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.30, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.32, using url 0, auto save disable 0. Oct 1 11:51:47 cli[1721]: <341004> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Isc_send_request Oct 1 11:51:50 cli[1721]: <341005> <ERRS> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| APAS provision failed, code: fail-prov-no-shipped Oct 1 11:52:02 cli[1721]: <341004> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Activate failed, enabling factory SSID Oct 1 11:52:08 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.18, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:11 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.26, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:11 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.15, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:11 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.22, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:11 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.34, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:11 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.21, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:11 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.23, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:12 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.28, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:12 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.25, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:12 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.17, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:12 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.33, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:12 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.37, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:12 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.27, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:12 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.31, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:12 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.20, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:12 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.35, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:12 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.29, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:12 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.36, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:12 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.19, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:50 cli[1721]: <341004> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Isc_send_request Oct 1 11:52:54 cli[1721]: <341005> <ERRS> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| APAS provision failed, code: fail-prov-no-shipped Oct 1 11:53:06 cli[1721]: <341108> <ERRS> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| sess_validate_sid: 179 invalid session client-38.108.87.99 sid-ba0dbb1d97e6c52ef3602e5f376e. Oct 1 11:54:53 cli[1721]: <341004> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Isc_send_request Oct 1 11:54:56 cli[1721]: <341005> <ERRS> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| APAS provision failed, code: fail-prov-no-shipped Oct 1 11:54:57 cli[1721]: <341097> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| recv_image_check: mac-9c:1c:12:cc:ae:40, version-6.4.0.2-4.1.0.0_44004, ccode_idx-255. Oct 1 11:55:01 cli[1721]: <341004> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Image_sync_via_master_file Oct 1 11:55:01 cli[1721]: <341004> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_image_mismatch url (ap classPegasus) to 192.168.10.24 Oct 1 16:56:08 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.36, slave 60442 vs master 64600, error_cnt 1, recover_sent 0. Oct 1 16:56:11 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.18, slave 60442 vs master 64600, error_cnt 1, recover_sent 0. Oct 1 16:56:15 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.15, slave 60442 vs master 64600, error_cnt 1, recover_sent 0. Oct 1 16:56:15 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.22, slave 60442 vs master 64600, error_cnt 1, recover_sent 0. Oct 1 16:56:15 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.34, slave 60442 vs master 64600, error_cnt 1, recover_sent 0. Oct 1 16:56:15 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.21, slave 60442 vs master 64600, error_cnt 1, recover_sent 0. Oct 1 16:56:15 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.28, slave 60442 vs master 64600, error_cnt 1, recover_sent 0. Oct 1 16:56:15 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.23, slave 60442 vs master 64600, error_cnt 1, recover_sent 0. Oct 1 16:56:15 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.25, slave 60442 vs master 64600, error_cnt 1, recover_sent 0. Oct 1 16:56:15 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.27, slave 60442 vs master 64600, error_cnt 1, recover_sent 0. Oct 1 16:56:15 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.37, slave 60442 vs master 64600, error_cnt 1, recover_sent 0. Oct 1 16:56:15 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.31, slave 60442 vs master 64600, error_cnt 1, recover_sent 0. Oct 1 16:56:15 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.20, slave 60442 vs master 64600, error_cnt 1, recover_sent 0. Oct 1 16:56:15 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.35, slave 60442 vs master 64600, error_cnt 1, recover_sent 0. Oct 1 16:56:15 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.17, slave 60442 vs master 64600, error_cnt 1, recover_sent 0. Oct 1 16:56:15 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.29, slave 60442 vs master 64600, error_cnt 1, recover_sent 0. Oct 1 16:56:15 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.33, slave 60442 vs master 64600, error_cnt 1, recover_sent 0. Oct 1 16:56:16 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.19, slave 60442 vs master 64600, error_cnt 1, recover_sent 0. Oct 1 16:56:16 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.30, slave 60442 vs master 64600, error_cnt 1, recover_sent 0. Oct 1 16:56:16 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.32, slave 60442 vs master 64600, error_cnt 1, recover_sent 0. ********************************************************************************************************* 10/1/2014 12:55:55 PM Target: 9c:1c:12:cc:af:a8 Command: show log system ********************************************************************************************************* Oct 1 11:51:14 cli[1721]: <341097> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| recv_image_check: mac-9c:1c:12:cc:ad:66, version-6.4.2.0-4.1.1.0_46028, ccode_idx-255. Oct 1 11:51:14 cli[1721]: <341165> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send image match to 192.168.10.27. Oct 1 11:51:14 cli[1721]: <341097> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| recv_image_check: mac-9c:1c:12:cc:e3:54, version-6.4.2.0-4.1.1.0_46028, ccode_idx-255. Oct 1 11:51:14 cli[1721]: <341165> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send image match to 192.168.10.31. Oct 1 11:51:14 cli[1721]: <341097> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| recv_image_check: mac-9c:1c:12:cc:ae:f8, version-6.4.2.0-4.1.1.0_46028, ccode_idx-255. Oct 1 11:51:14 cli[1721]: <341165> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send image match to 192.168.10.35. Oct 1 11:51:14 cli[1721]: <341097> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| recv_image_check: mac-9c:1c:12:cc:ae:38, version-6.4.2.0-4.1.1.0_46028, ccode_idx-255. Oct 1 11:51:14 cli[1721]: <341165> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send image match to 192.168.10.20. Oct 1 11:51:14 cli[1721]: <341097> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| recv_image_check: mac-9c:1c:12:cc:77:1a, version-6.4.2.0-4.1.1.0_46028, ccode_idx-255. Oct 1 11:51:14 cli[1721]: <341165> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send image match to 192.168.10.29. Oct 1 11:51:14 cli[1721]: <341097> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| recv_image_check: mac-9c:1c:12:cc:b0:90, version-6.4.2.0-4.1.1.0_46028, ccode_idx-255. Oct 1 11:51:14 cli[1721]: <341165> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send image match to 192.168.10.19. Oct 1 11:51:14 cli[1721]: <341097> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| recv_image_check: mac-9c:1c:12:cc:ad:68, version-6.4.2.0-4.1.1.0_46028, ccode_idx-255. Oct 1 11:51:14 cli[1721]: <341165> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send image match to 192.168.10.36. Oct 1 11:51:14 cli[1721]: <341097> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| recv_image_check: mac-9c:1c:12:cc:ae:ea, version-6.4.2.0-4.1.1.0_46028, ccode_idx-255. Oct 1 11:51:14 cli[1721]: <341165> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send image match to 192.168.10.30. Oct 1 11:51:15 cli[1721]: <341097> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| recv_image_check: mac-9c:1c:12:cc:b0:4c, version-6.4.2.0-4.1.1.0_46028, ccode_idx-255. Oct 1 11:51:15 cli[1721]: <341165> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send image match to 192.168.10.32. Oct 1 11:51:16 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.18, using url 0, auto save disable 0. Oct 1 11:51:16 cli[1721]: <341097> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| recv_image_check: mac-9c:1c:12:cc:ae:40, version-6.4.0.2-4.1.0.0_44004, ccode_idx-255. Oct 1 11:51:21 cli[1721]: <341004> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Image_sync_via_master_file Oct 1 11:51:21 cli[1721]: <341004> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_image_mismatch url (ap classPegasus) to 192.168.10.24 Oct 1 11:51:21 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.15, using url 0, auto save disable 0. Oct 1 11:51:21 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.26, using url 0, auto save disable 0. Oct 1 11:51:21 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.34, using url 0, auto save disable 0. Oct 1 11:51:21 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.22, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.21, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.23, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.28, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.17, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.25, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.37, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.33, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.27, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.31, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.20, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.35, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.29, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.19, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.36, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.30, using url 0, auto save disable 0. Oct 1 11:51:22 cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_config_init: send config to slave 192.168.10.32, using url 0, auto save disable 0. Oct 1 11:51:47 cli[1721]: <341004> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Isc_send_request Oct 1 11:51:50 cli[1721]: <341005> <ERRS> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| APAS provision failed, code: fail-prov-no-shipped Oct 1 11:52:02 cli[1721]: <341004> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Activate failed, enabling factory SSID Oct 1 11:52:08 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.18, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:11 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.26, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:11 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.15, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:11 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.22, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:11 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.34, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. ent 0. Oct 1 11:52:11 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.23, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:12 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.28, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:12 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.25, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:12 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.17, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:12 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.33, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:12 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.37, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:12 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.27, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:12 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.31, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:12 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.20, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:12 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.35, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:12 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.29, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:12 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.36, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:12 cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Check sum error for AP-192.168.10.19, slave 8438 vs master 60442, error_cnt 1, recover_sent 0. Oct 1 11:52:50 cli[1721]: <341004> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Isc_send_request Oct 1 11:52:54 cli[1721]: <341005> <ERRS> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| APAS provision failed, code: fail-prov-no-shipped Oct 1 11:53:06 cli[1721]: <341108> <ERRS> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| sess_validate_sid: 179 invalid session client-38.108.87.99 sid-ba0dbb1d97e6c52ef3602e5f376e. Oct 1 11:54:53 cli[1721]: <341004> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Isc_send_request Oct 1 11:54:56 cli[1721]: <341005> <ERRS> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| APAS provision failed, code: fail-prov-no-shipped Oct 1 11:54:57 cli[1721]: <341097> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| recv_image_check: mac-9c:1c:12:cc:ae:40, version-6.4.0.2-4.1.0.0_44004, ccode_idx-255. Oct 1 11:55:01 cli[1721]: <341004> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| Image_sync_via_master_file Oct 1 11:55:01 cli[1721]: <341004> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli| send_image_mismatch url (ap classPegasus) to 192.168.10.24
Noticing that the AP couldn't get its firmware from the VC, I downgraded the cluster to 4.1.0.0, voila, all 23 APs are online.
Then upgraded it to 4.1.0.1 and 4.1.1.0 and the same situation happens with the same AP, only 22 appear not the 23rd.
Had to downgrade to 4.1.0.0 in order to deploy the network.
Any idea what could be causing this? faulty AP possibly? But it works on the shipped firmware.
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: IAP-103 will not join cluster
10-01-2014 10:32 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
10-08-2014 06:54 AM
ACDX #420 | ACCA
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
