Frequent Contributor II
IAP 104 Home Deployment
What antenna would you recommend for a IAP 104 deployment in a large home?
Re: IAP 104 Home Deployment
If it is large home and there are walls and furniture, you probably will not be able to cover it with a single access point.  External antennas do not increase the output power: they change the "shape" of the radiated power; so if you have a directional antenna, it will put more power in one direction and less in the opposite direction.  You are better off using multiple access points or use external antennas if you want the coverage to be "shaped" in a way that does not resemble the 105s coverage.
Thanks for the reply.
The home is about 5500 sq ft.  I am deploying 3 IAP 104's, one on each floor.  Would you use the AP-ANT-1F?
The 1F will give it a more doughnut-shaped type of coverage which covers more horizontal area than an AP105.  That is what I would use, if that is what type of coverge you want.
What gain should I be using for 2.4 and 5.
The website suggests 2dbi for the 2.4 and 5dbi for the 5.
Is this correct?
