IAP 104 and IAP 175 support for number of IAPs on single IAP
I researching product Aruba IAP 104 and 175. I want to know "” single IAP 104/175 can control to 64 IAPs or not ?”.
If not, how many these product support IAP ?
Thank
Re: IAP 104 and IAP 175 support for number of IAPs on single IAP
Yes you can have 64x IAP104/IAP175 in one virtual controller.
[ Edited ]
Thank ariyap
and IAP 92, 93, 105, 134, 135 support ???
Can you send for me that document ?
Help me !
As long as you do not have IAP92/93 in the mix, you can go up to 64 IAPs.
but as soon as you introduce IAP92/93 in the mix, then you can only go up to 16 IAPs.
[ Edited ]
Mean:
I understand " IAP 92, IAP 93 support up to 16 IAP" & IAP 105, IAP 134, IAP 135 can up to 64 IAP" ??
Do i understand is correct ??
Can you send for me document ( document writted this problem)  ?
[Personal Information Removed]
Thank ariyap so much
