IAP 105 Master issue
  • 1.  IAP 105 Master issue
    Posted May 02, 2013 10:34 AM
    I have just installed an IAP 105 cluster.  The issue I have is.  When the master IAP is rebooted, It does not take over the role of master.  It just blinks Red lights on the antenna's until I reboot the current elected master.
    Any Ideas.  If this is a repost I am sorry, I could not find a similar post.
  • 2.  RE: IAP 105 Master issue
    Posted May 02, 2013 10:43 AM
    What IAP OS code are you running ?
  • 3.  RE: IAP 105 Master issue
    Posted May 02, 2013 10:45 AM
    Do you have "Auto-Join" enabled or disabled?
    No IAP in a cluster is designated as a permanent Master / VC.  If the active VC goes offline another IAP will automatically take over as the new VC and will remain the VC until it goes offline / reboots.  This is, in part, based on system uptime.
    That being said, that IAP should re-join the group as a member so something is wrong.
    What version of SW are you running?  v.3.3 is the current and has a number of fixes for similar issues.  Without TAC involvement, however, I don't know if you are hitting one of these issues but this is an easy thing to try.
  • 4.  RE: IAP 105 Master issue
    Posted May 08, 2013 02:13 PM
    I rebooted all the other IAP's and the .25 AP came back on line.  I was able to run the firmware upgrade to the AP's and all AP's came back up with the new Firmware.
  • 5.  RE: IAP 105 Master issue
    Posted May 13, 2013 02:20 PM
    I rebooted the other 16 AP's and the .25 AP came online.  We upgraded to the latest firmware last Wednesday night and all AP's were active.  This morning I was informed that the AP was down again this morning Antenna showing red.  The only way to have it come online is to reboot all the other AP's.
  • 6.  RE: IAP 105 Master issue
    Posted May 13, 2013 03:09 PM
    Please open a case with TAC to do further debugging.
  • 7.  RE: IAP 105 Master issue
    Posted Jun 18, 2013 08:50 AM
    The issue was resolved.
    I had the VC IP the same as one of the IAP's.  Once I changed the IP of the switch.  I no longer had issues with the Master Role.
  • 8.  RE: IAP 105 Master issue
    Posted Oct 10, 2013 11:41 AM
    I am deploying multiple iAP105's .  Does seperating the ip of the ap from the virtual controller mean that i wont really know which ap is the controller?  Does it matter?
    is there a place where i set the ip for the virtual controller so i can always browse to it ?
    thanks for your help.
  • 9.  RE: IAP 105 Master issue
    Posted May 02, 2013 05:12 PM
    Edit.....removed as looks to be answered correctly.
