IAP-105 Not joining cluster
So I've done a bunch of reading and looked at several posts. I cannot find an answer to my issue.
I have two IAP-105-JP. One has been set up with a main SSD and a guest SSD. It has a static IP, auto join is on, it is set to preferred master, plugged into the same switch which has only one VLAN. They have the same firmware.
The other one has a static IP, auto join is on, and it is plugged into the same switch. On the advanced system page, I did not put in the IP of the Virtual Controller.
I have looked at the logs and really do not see anything that jumps out at me.
So what do I need to do to the unconfigure IAP-105-JP to have it join with the configured one.
Thank you in advance
Re: IAP-105 Not joining cluster
You should try making the second AP DHCP if possible.
Set it to DHCP. Rebooted IAP.
How long does it take to auto join?
Been about 30 minutes.
Can you ping the AP?  SSH into the AP when you can ping it and type "show log system" to see what is happening to it....
Yes. I was able to SSH and ran the attached log.
You should reset that IAP, then try to join it to the cluster:
http://community.arubanetworks.com/t5/Controller-less-WLANs/Where-is-the-reset-button-on-the-IAP-and-how-do-I-reset-the-IAP/ta-p/180980
So I did a reset and still not joining. I changed the admin password to match the master.
I left everyhting else alone.
Log attached
Do you have auto join enabled in the Virtual Controller?  http://www.arubanetworks.com/techdocs/Instant_423_WebHelp/InstantWebHelp.htm#UG_files/GeneralConfTasks/System_parameters.htm?Highlight=join
Yes, auto join is on.
Are they are on the same subnet?  It seems like that AP does not "see" any other APS.
