Contributor I
IAP 105 and AirWave - 1 SSID with Captive Portal and MAC Auth
I am trying to figure out how to set up an IAP 105 to work with both Captive Portal and MAC Auth.  I already have a guest SSID setup that is doing Captive Portal but there is now a need to have a few of our hosts bypass the Captive Portal and sign on with MAC Auth.  Is this possible with IAP 105s and AirWave?
Frequent Contributor II
Re: IAP 105 and AirWave - 1 SSID with Captive Portal and MAC Auth
Yes, this should be possible.
What are you using for the authentication server? Internal or external RADIUS server?
ACMX#255 | ACDX#742 | ACCX#746 | AMFX#25 | ACMP | ACCP | AWMP
www.securelink.nl
Contributor I
I was thinking of using our ClearPass server.  Looking into how to setup on boarding with the end device.
Super Contributor I
A couple of things like setup of CA, the onboarding pages etc. Check with your local SE if need to.
Normal Guy
If you just want to add MAC authentication you don't need onboarding. For MAC authentication you can use the endpoint repository as your authentication source.
www.securelink.nl
