IAP 105 and IAP 205
  • 1.  IAP 105 and IAP 205
    Posted Nov 29, 2017 02:31 AM
    Hi guys,
    Would it be possible to add IAP 205's to and existing IAP 105 Cluster of 7?
  • 2.  RE: IAP 105 and IAP 205
    Posted Nov 29, 2017 02:25 PM
    Yes!
    They just need to be running the version of code.
  • 3.  RE: IAP 105 and IAP 205
    Posted Nov 30, 2017 03:25 AM
    Hi Jamie,
    Thanks again for your help, I see the code available for both these IAP's is 6.4.4.4-4.2.3.2 (Orion for the 105 and Taurus for the 205). So as long as both sets of IAPS are the same version of code I should be OK, Any idea what code the 205 comes bundled with? it doesn't state this on the reseller full specification  details. If I upgrade the existing 105 IAPS to that code and then join them to the cluster successfully I should be OK to upgrade all IAP's to latest compatible code for both sets, is that correct?
  • 4.  RE: IAP 105 and IAP 205
    Posted Nov 30, 2017 03:42 AM
    Just found the data sheet for the 205,
    • ArubaOS 6.4.1.0
    • Aruba InstantOS 4.1.1.0
    I'm assuming this is the bundled software, correct?
  • 5.  RE: IAP 105 and IAP 205
    Posted Nov 30, 2017 04:34 AM
    Those are just the minimums.  It could come with software that is newer than that.  You also can upgrade to anything in the Limited Lifetime Waranty page here:  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/EntryId/20374/Default.aspx
  • 6.  RE: IAP 105 and IAP 205
    Posted Nov 30, 2017 06:31 AM
    Hi Colin,
    Thanks again or the info, can I get the the curently installed code of an IAP using the console port?
  • 7.  RE: IAP 105 and IAP 205
    Posted Nov 30, 2017 06:39 AM
    When it boots up, it will tell you what version it is running.  If you cannot get into the console, you would type "show version"
