Frequent Contributor I
IAP 105 and IAP 305 in same cluster?
What software version do I have to be running for the IAP105 and 305 to work in the same cluster?
Re: IAP 105 and IAP 305 in same cluster?
That will not be possible as the IAP-105 will run firmware up to 4.2, where the IAP-305 will run firmware 4.3.1.0 and up.
will IAP205 and 305 work together?
Aruba
Yes, as long as the software is 4.3.1.0 or later.
/Onno
