Trusted Contributor I
IAP 105 as CAP with lower ArubaOS
i was wondering if i can expect Aruba IAP 105s to function normally as CAPs with ArubaOS 6.0.x / 6.1.x ? im using them to test an upgrade from ArubaOS 6.0.1.1 to 6.1.3.7 and get some odd results, especially DHCP from the APs not working anymore. DHCP does work for other devices, so it does seem to be an AP issue.
[edit] so not the converting, that was done in the past and the AP did seem to register correctly on the 6.0.1.1 system.
Re: IAP 105 as CAP with lower ArubaOS
probably working fine, seemed to have run into some network issue. did it all again today without issues, apologize for the chatter.
