IAP-105 compatibility with a controller running 3.4.x code
Hi guys,
I need to know if the IAP-105 can be used as a campus AP with a controller running 3.4.X code.
I checked the AP matrix document and says that the minimum supported code for the AP-105 is the 3.4.1.0 code BUT the Instant version IAP-105 supports the 1.0.0.X.
So I've noticed that the name of an Instant image comes with 2 names of versions, like 5.0.3.0-1.0.0.X or 6.2.1.0-3.3.0.X for an example. What does that mean? Does that mean that the instant image 1.0.0.X can work with a 5.0.3.0 controller as a minimum?
Thanks in advance for you help.
Re: IAP-105 compatibility with a controller running 3.4.x code
That OS for the actual IAPs , when you have IAPs setup as standalone (not RAPs or Campus APs) you can upgrade the image
I believe that in order for you to do this you need to have on your controller AOS 6.1.4.x or 6.2.x
The 1.0.0.x is the minor version of 5.0.3.0-1.0.0.x not an actual range
Thank you
Victor Fabian
Lead Mobility Architect
Hey, thanks for your reply,
So I'm assuming that I need a 6.1.4.x version as minimum in order to use a IAP-105 as a CAP right?
That's correct.
Thank you
Victor Fabian
Hi there,
I just wanted to clarify this a little bit more. I opened a case with Aruba team just to be sure about this and here's what they found:
In order to convert an IAP-105(with latest image) to a normal campus AP we need a minimum of 6.1 image on the Aruba controller.
However if the IAP-105 is running 5.0.3.1-1.0.0.1 image on it, we only need a minimum OS version of 5.0.3.0 on the controller.
Good to know...Thanks
Thank you
Victor Fabian
