IAP 105 external web authentication
In the IAP 105 there is an option for the IAP to direct the user for the web authentication to a remote web server, and to set an authentication text.
Is there any template to how the web page should send the authentication text?
Best regards,
Omer Shtivi
Valued Contributor I
Re: IAP 105 external web authentication
You can do this for the Guest network. Create a new network with the type set to Guest > use Virtual Controller assigned for the IP Address and set a static vlan if needed, then under security set the Splash Page for External - RADIUS Server.
See the screen capture below. Also see the Authentication chapter in the IAP User's Guide under the heading "External Captive Portal".
Thank you,
But I still doesn't get how the radius server and the web page communicate
Contributor II
Hi, did you find a template to do that?
Thank you
