Occasional Contributor I
IAP 105 keep on rebooting
Hi All,
Have anyne come across this issue? i have 5 ap 105 and all keep on reebooting with error(screenshot). DHCP is enable on the network.Level 49.png
MVP
Re: IAP 105 keep on rebooting
Please read this bulletin
this could be your issue
Cheers
Carlos
Alternetworks Corp
Hi Carlos,
I wil check the S/N and the details..
thanks
MVP
If that is not your issue,  What i mean is that your ap does not belong to those Serial numbers.  Then your AP must be flaulty and you might need to open a support case to make them change the ap to you.
Cheers
Carlos
Alternetworks Corp
Hi Carlos,
Based on your experience, If that is not the issue(my AP not belong to those S/N), the error indicate the the AP is faulty?
MVP
When you got crazy errros like this all you can do is
clear os
reboot and if it keep happening which i guess it will, you will need to open a support case and tell them that you already did clear os becasue they always tells you to do
factory default
clear os
If that doesnt work and you keep getting those errors they will RMA your APS, as there is nothing else you can actually do besides that.
To not loose time tell the tac
if you already did it
I already did clear OS, i also read the field bulletin AP-100-TMP and i verified that the serials does not belong to that range... and ask them to please to RMA your AP.
They will just asnwer you to give them your address etc etc.
Cheers
Carlos
Alternetworks Corp
Hi Carlos,
Noted with thanks
MVP
Dont worry we are all here to help :)
Cheers
Carlos
Alternetworks Corp
