IAP 105 rebooting
I am having mutliple IAP 105 that are rebooting through out our campus and I am trying to find out why they rebooting.
We are running the latest firmware on them
Name:
Aruba Operating System Software
Type:
105
Build Time:
2014-06-05 09:52:43 PDT
Version:
6.3.1.4-4.0.0.6_44126
I am unable to locate a reason why. The ap's are scattered through out our campus on various switches
Re: IAP 105 rebooting
Can you see if there's any errors in switch logs ?
This might be a layer 2 issue .
Have you made any recent changes to your network ?
Thank you
Victor Fabian
Lead Mobility Architect
Have you checked to see if maybe STP is blocking the ports randomly for some reason?
ACDX #419 | ACMP |
Contributor I
Did these AP's even work to begin with?  Are they in the same AP group?  Are they on the same local controller(If you have a master-local setup)?
