IAP-115 Fast Ethernet Uplink
has anyone had major problems using 100Mbps uplinks for IAP-115's rather than 1Gbps uplinks?
The customer has 10 X IAP-115's.
Re: IAP-115 Fast Ethernet Uplink
JazzyT,
Are you having specific problems, or are you checking to see if they work on 100 megabit interfaces?
The VC looks like it is losing contact to the other AP's. The slave AP's 'drop' off and reconnect every few minutes. My guess is network congestion.
