IAP 115 running 4.2.1.0 randomly blocks websites with OpenDNS
this is odd, it has happened twice to me now where I visit a website and get denied access by OpenDNS when connected to my IAP-115 using 4.2.1.0.
OpenDNS is NOT configured on the IAP. Anyone see this before?
I disconnect from the SSID, re-connect, and the problem goes away.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Re: IAP 115 running 4.2.1.0 randomly blocks websites with OpenDNS
Pmonardo,
Do you have content filtering enabled at all?  Please PM me your configuration.
no content filtering anywhere.
config was PM'ed.
That evening I upgraded to 4.2.1.1.
If I recall correctly the first time this happened was on 4.2.0.1.
ACDX #420 | ACCA
misconfiguration on the latest attempt with 215 and 4.1.3
ACDX #420 | ACCA
