IAP-175 and IAP-93 in same cluster
We got the following scenario, one cluster running 5 IAP-105 and another cluster running one IAP-175 and 5 IAP-93, the management is done via Uplink Management Vlan 500 instead of native on the second cluster.
The IAP-93 are working fine and we have one 93 as VC, but the IAP-175 does not provision from that VC what are we doing wrong.
Thanks!
MVP
Re: IAP-175 and IAP-93 in same cluster
[ Edited ]
Check in the INFO frame (in GUI) what is the country code that the VC 93 IAP is in? Is it the same country code like your iAP175 unit?
*Check it - if it's not the same country code in both units - the iAP175 will not provision into this VC.
*Make sure you are using the lastest available InstantAP OS version. (It's always good)
Me.
MVP
Thats my picture! got stolen ;P  hehe
Alternetworks Corp
MVP
HaHA :) Google gave it to me ;)
Thanks a lot, i solved the issue!
