In a school enviroment with an IAP-205 in each classroom is it better to disable 80Mhz support and / or Very High Throughput?
I am in the England.
Jason
Thanks Tim.
@cappalli wrote:In most environments it is recommended to disable 80MHz channels, but leaveVHT enabled. You may want to work with your partner to design a solution foryour environment.
