IAP 205 Firmware Upgrade Not Applying
Has anyone experienced issues with firmware not applying? I've just tried to update some IAP 205s in several remote sites using the automatic update and whilst they all say the upgrade succeeded when they reboot and I log back on they are still running the old firmware.
We were upgrading from 6.4.2.3-4.1.1.4_49446 to 6.4.2.6-4.1.1.10_51810.
I'm wondering if the firmware download may have timed out so want valid hence why it wasnt applied although I would think that would result in a failed update message.
I also have one set of APs at one site that seem to have lost the admin password after they rebooted. It was obviously working when we initiated the upgrade but now I don't know what it has been reset to. I'm not even sure if the configuration is still intact but it seems to be as the APs still have the IP addresses assigned. Such a pain - will probaby have to go out to site and recover or reset the APs.
Re: IAP 205 Firmware Upgrade Not Applying
are you upgrading using the cloud or manually uploading the firmware?
what do the logs say?
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Occasional Contributor I
Hi Tymbow
I had same issue, iAPs 105 has no problem upgrading.
My scenario is similar to yours upgrading the iAP 205. I did a manual upgrade with no reboot option in the web GUI.
After the upgrade said succesfull, I left the APs untill late evening to reboot.
Rebooted and only 1 was back into the VC/Cluster. The problem was that it still booted into the old image...
So eventually I had to ssh into each iAP205 (Some with local user admin and some with my Radius account), I confirmed that the upgrade image was in the backup partition with the cmd "show image" and verify the image it was booted in with "show version".
All the AP's booted into the primary pation, but the old image was on the primary partition, the new image was infact on the APs, but in the backup partition.
"show image" output:
Primary Partition Build Time :2015-05-12 10:27:51 PDT
Primary Partition Build Version :6.4.2.6-4.1.1.6_50009
Backup Partition Build Time :2016-05-29 23:07:01 PDT
Backup Partition Build Version :6.4.2.6-4.1.3.1_55246
AP Images Classes
Class
Taurus
ssh back into all the AP's and then I did the "switch-partition-reboot" cmd on all the AP's at the same time and after this  they all come back on with the new image in the primary partition.
verify commands:
"show version" and "show image"
Hope this helps. as a side note, one AP took about 10min to show up in the GUI cluster.
