IAP-205 Guest SSID not separated from private net.
I've setup a IAP-205 with a private/public SSID config.
I've got a DHCP scope setup on the IAP with a captive portal.
Trafic is working on both networks, a little too well on the public SSID.
The puclic SSID is still able to access resources on the private network. I'm sure I'm overlooking something extremely simple, but since this is my first go at that IAP I need a bit of help.
Thanks.
Topology:
Internet Router -> ASUS RT-AC66U -> IAP-205 (6.4.2.0-4.1.1.0_46028)
Re: IAP-205 Guest SSID not separated from private net.
Did you create a network-based access rule to block your internal network?
Tim Cappalli | Aruba Security
That was it.
I knew it was something simple I was overlooking.
Thanks.
