IAP-205 client doesn't connect
Hello all!
I have two new IAP-205, one works fine, but the second one has an issue. Wireless clients cannot connect. What should be the reason?
Software version 6.4.2.0-4.1.1.
 RSI attached.
Here is logs:
Spoiler
b4:5d:50:ca:77:1c# show log kernel
ay 8 09:38:17 2017:411 168347.082047 Client Match: no vbr to delete 44:00:10:66:cd:a7
[168366.812000] wl0: wlc_recvfilter: scb is null, dont resend deauth
[168367.234000] Mon May 8 09:38:17 2017:412 168347.505181 Client Match: wifi1: client count error
[168367.234000] Mon May 8 09:38:17 2017:413 168347.505226 Client Match: no vbr to delete 44:00:10:66:cd:a7
[168377.064000] Mon May 8 09:38:27 2017:414 168357.334814 anul_wids_update_cpu: Priority traffic has STOPPED
[168377.594000] Mon May 8 09:38:27 2017:415 168357.865018 anul_wids_update_cpu: Priority traffic has STOPPED
[168399.124000] wl1: wlc_recvfilter: scb is null, dont resend deauth
[168461.678000] wl1: wlc_recvfilter: scb is null, dont resend deauth
[168463.000000] wl0: wlc_recvfilter: scb is null, dont resend deauth
[168497.796000] wl1: wlc_recvfilter: scb is null, dont resend deauth
[168537.246000] Mon May 8 09:41:07 2017:416 168517.516209 Client Match: wifi1: client count error
[168537.246000] Mon May 8 09:41:07 2017:417 168517.516255 Client Match: no vbr to delete 44:00:10:66:cd:a7
[168537.268000] wl1: wlc_recvfilter: scb is null, dont resend deauth
[168537.840000] Mon May 8 09:41:08 2017:418 168518.110882 anul_prio_traffic_set_time: Priority traffic has STARTED
[168537.852000] Mon May 8 09:41:08 2017:419 168518.122471 Client Match: wifi1: client count error
[168537.852000] Mon May 8 09:41:08 2017:420 168518.122516 Client Match: no vbr to delete 44:00:10:66:cd:a7
[168544.090000] wl0: 1 rx fifo 0 overflows!
[168547.934000] Mon May 8 09:41:18 2017:421 168528.204932 anul_wids_update_cpu: Priority traffic has STOPPED
[168591.258000] Mon May 8 09:42:01 2017:422 168571.528128 Client Match: wifi1: client count error
[168591.258000] Mon May 8 09:42:01 2017:423 168571.528174 Client Match: no vbr to delete 44:00:10:66:cd:a7
[168591.272000] wl1: wlc_recvfilter: scb is null, dont resend deauth
[168594.972000] Mon May 8 09:42:05 2017:424 168575.243604 anul_prio_traffic_set_time: Priority traffic has STARTED
[168594.980000] wl1: wlc_recv_mgmt_ctl: unhandled frametype (fk 0xd4)
[168594.986000] Mon May 8 09:42:05 2017:425 168575.257250 Client Match: wifi1: client count error
[168594.986000] Mon May 8 09:42:05 2017:426 168575.257294 Client Match: no vbr to delete 44:00:10:66:cd:a7
[168594.992000] wl1: wlc_recvfilter: scb is null, dont resend deauth
[168594.996000] wl1: wlc_recvfilter: scb is null, dont resend deauth
[168595.000000] wl1: wlc_recvfilter: scb is null, dont resend deauth
[168605.048000] Mon May 8 09:42:15 2017:427 168585.318948 anul_wids_update_cpu: Priority traffic has STOPPED
[168611.226000] stats > 100: ccastats_us: 76158, acc->statss_ms: 76
[168679.526000] stats > 100: ccastats_us: 76149, acc->statss_ms: 76
[168698.318000] wl1: wlc_recvfilter: scb is null, dont resend deauth
[168870.436000] wl1: wlc_recvfilter: scb is null, dont resend deauth
[168873.080000] stats > 100: ccastats_us: 22131, acc->statss_ms: 22
[168886.728000] wl1: wlc_recvfilter: scb is null, dont resend deauth
[168886.852000] wl1: wlc_recvfilter: scb is null, dont resend deauth
[168886.978000] wl1: wlc_recvfilter: scb is null, dont resend deauth
Re: IAP-205 client doesn't connect
Do you have all client VLANs trunked to that IAP?
If you are using radius, do you have Dynamic Radius Proxy enabled?
Colin Joseph
Aruba Customer Engineering
Hi Support Team:
                         I meet same issue like this.The situation was not connected to iap205 when users number over 30.
That was happend 2 days ago that have a lot customer visit.
This site have two IAP205 and a radius server on lan.
DHCP server own class c ip to assignment.
Because radius server only charge for employee user authentication.
Do i enable the dynamic radius proxy?
Please refer attached file of dump.
