IAP 205H WAN port
HI All,
In IAP-205H, which port shall i connect to router (default gateway), is it Eth 0 ?
Also how do i configure this port to set ip address statically or via dhcp ?
Re: IAP 205H WAN port
Port 0 is the default uplink on an Instant AP. You configure the IP address via the Instant UI (connect to the instant SSID and open a browser).
Tim Cappalli | Aruba Security
Is it also mentioned in user , like which tab will allow be to configure it? sorry for such a dumb question, i am just starting out so getting a bit lost in all the options :)
If you click on the AP in the dashboard and click edit, you can set the IP address.
I check this user guide
http://www.arubanetworks.com/techdocs/InstantMobile/Advanced/Content/Instant%20User%20Guide%20-%20volumes/Uplink%20Configuration.htm
it says
Instant does not support configuration of an Eth0 uplink.
You're configuring the IP address of the AP, not the uplink of the port itself....
No, I want to configure ip address on the uplink port. Is it the same as configuring ip address of AP itself or is it different.
Basically my idea is, AP will use this IP to connect to its default gateway (Router).
Best Regards
Ovais Iqbal
HP MASE Infrastructure/ CCIE # 37956 (R&S)
Solution Architect
HP Networking
Hewlett Packard Enterprise
Yes, the AP's IP will be used.
Hi Tim,
Sir on my mentioned link
why it says
please help me understand
I'm sorry, but I'm not following you. Please work with your Aruba Partner who can assist with your requirements.
