IAP 205H to Campus WLAN AP convertion failed
Hi all,
I'm trying to convert a IAP 205H in order to control it with my 7005 controller.
I already converted successfully a IAP 215, but for the IAP 205H, I have the following error (and so convertion does not work):
08:45:05 (28.47 MB/s) - `armv7ns.ari' saved [6495248]
cleaning up
done
----------Download log end------------
Download status: Image verify fail
----------Upgrade log start----------
upgrade log not available
----------Upgrade log end------------
Upgrade status: upgrade status not available
end of show log upgrade
The IAP release is : 6.4.3.0-4.2.0.0_49453
And the controlelr release: 6.4.2.3
Can somebody help please ?
Fabien GIRAUD
Re: IAP 205H to Campus WLAN AP convertion failed
Upgrade your controller to 6.4.3.x
Tim Cappalli | Aruba Security
Hi thanks for the quick answer,
That was also my thoughts but I have an issue with my account. It seems that my HP account is not well defined in the Aruba support site.
I have a fantastic"User With No role" and so I can't access the firmware download area ...
Is there any other place were I can download it (Arubapedia, SEEL or somewhere else ???).
Fabien
PM me your email address.
Also, to fix your account, contact Aruba TAC (support@arubanetworks.com)
Fantastic,
It works !!!
Many many thanks
