IAP 215 Hidden or Disabled Instant SSID
I have an IAP 215 and I have had an engineer check the box for hide or disable the instant (default) ssid.  I would like it back.  anyone have thought on this I have cli access and GUI
Re: IAP 215 Hidden or Disabled Instant SSID
http://community.arubanetworks.com/t5/Controller-less-WLANs/How-do-I-hide-an
-SSID-in-an-Aruba-Instant-AP/ta-p/181310
Tim Cappalli | Aruba Security
My Appologies on the poor wording of the question.
at this time I do not see in the GUI or clsi the "Default" ssid that came with the IAP due to an engineer either hiding it or deleteing . can I just remake it or can I unhide or un disable that SSID?
The "instant" SSID?
 yes sir the instant SSID
Can you please post a screenshot of your GUI?
The "instant" SSID is only used during setup and is automatically removed
once a new network is created.
after removing all of my WLAN's and rebooting my access point my "instant" SSID has came back.  I'm all set now.  with thi part of my issues.  I thank you for your time.
