Contributor I
IAP-215 doesn't send Instant SSID even after reset button.
Hi
Even after I reset button to initialize IAP-215, I can never see "Instant" SSID.
Is there any configuration not be deleted by even a reset button?
The LED after boot up with reset button is shown below.
https://www.fastpic.jp/viewer.php?file=1955610713.jpg
Without seeing an Instant SSID, I can't configure this IAP.
What else can I configure?
Four IAP-215 is same symptom, so it is not a hardwere failure.
Regards
Simon
Re: IAP-215 doesn't send Instant SSID even after reset button.
Hey, can you confirm the IAP is obtaining an IP address? Set up a DHCP server and plug in a console cable to confirm an IP address is being assigned.
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Hi Simon,
If you know the IP address assigned to this IAP, you can access the WebUi of this IAP from a wired machine by typing the IP address in the web browser.
Contributor I
I should have connected to DHCP server.. Thanks.
