I have an existing VC with 17 IAP-135's on it. It's been working fine for a year or more. I upgraded it to 6.4.2.6-4.1.1.7_50209 to ensure it would support the new IAP-215's I was going to add.
Unfortunately, none of the 215's will join the controller. The best I can tell, the problem is some sort of image mismatch. I have completed this exact process at another site and all the 215's came online to the VC without issue. Running same version and everyhing. Below is the log.
Thanks for your help.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.06.16 19:03:03 =~=~=~=~=~=~=~=~=~=~=~=
LCHS-NTN-25# sh log system
Jun 16 17:50:51 cli[2829]: <341199> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_config_init: send config to slave 10.9.2.101, using url 0, auto save disable 0.
Jun 16 17:50:51 cli[2829]: <341199> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_config_init: send config to slave 10.9.2.114, using url 0, auto save disable 0.
Jun 16 17:50:52 cli[2829]: <341199> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_config_init: send config to slave 10.9.2.102, using url 0, auto save disable 0.
Jun 16 17:50:52 nanny[2753]: <303073> <ERRS> |AP LCHS-NTN-25@10.9.2.120 nanny| Process /aruba/bin/radiusd-term [pid 5222] died: got signal SIGTERM
Jun 16 17:50:52 nanny[2753]: <303079> <ERRS> |AP LCHS-NTN-25@10.9.2.120 nanny| Restarted process /aruba/bin/radiusd-term, new pid 5420
Jun 16 17:50:57 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Isc_send_request
Jun 16 17:50:57 cli[2829]: <341005> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| APAS provision failed, code: connection-failed
Jun 16 17:51:40 cli[2829]: <341108> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| sess_validate_sid: 179 invalid session client-10.201.1.18 sid-AstftA9MrlmOklTyjSaq.
Jun 16 17:52:01 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-ac:a3:1e:c6:f8:b8, version-6.4.2.0-4.1.1.0_46028, ccode_idx-0.
Jun 16 17:52:01 cli[2829]: <341165> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send image match to 10.9.2.88.
Jun 16 17:52:06 cli[2829]: <341199> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_config_init: send config to slave 10.9.2.88, using url 0, auto save disable 0.
Jun 16 17:52:57 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Isc_send_request
Jun 16 17:52:57 cli[2829]: <341005> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| APAS provision failed, code: connection-failed
Jun 16 17:54:58 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c3:bb:94, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
Jun 16 17:54:58 cli[2829]: <341052> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check, 1637: AP class not match, Master-25, Slave-15.
Jun 16 17:54:58 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Image_sync_via_isc
Jun 16 17:54:58 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.222
Jun 16 17:56:15 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6f:04, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
Jun 16 17:56:15 cli[2829]: <341052> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check, 1637: AP class not match, Master-25, Slave-15.
Jun 16 17:56:15 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Image_sync_via_isc
Jun 16 17:56:15 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.239
Jun 16 17:56:15 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6a:c4, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
Jun 16 17:56:15 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.204
Jun 16 17:56:16 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6a:24, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
Jun 16 17:56:16 cli[2829]: <341052> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check, 1637: AP class not match, Master-25, Slave-15.
Jun 16 17:56:16 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Image_sync_via_isc
Jun 16 17:56:16 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.238
Jun 16 17:56:16 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6e:f4, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
Jun 16 17:56:16 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.243
Jun 16 17:56:16 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6a:f4, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
Jun 16 17:56:16 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.180
Jun 16 17:56:17 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6a:f0, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
Jun 16 17:56:17 cli[2829]: <341052> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check, 1637: AP class not match, Master-25, Slave-15.
Jun 16 17:56:17 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Image_sync_via_isc
Jun 16 17:56:17 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.172
Jun 16 17:56:17 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6d:b4, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
Jun 16 17:56:17 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.245
Jun 16 17:56:17 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6b:10, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
Jun 16 17:56:17 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.174
Jun 16 17:56:18 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6a:a8, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
Jun 16 17:56:18 cli[2829]: <341052> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check, 1637: AP class not match, Master-25, Slave-15.
Jun 16 17:56:18 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Image_sync_via_isc
Jun 16 17:56:18 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.242
Jun 16 17:56:19 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6a:4a, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
Jun 16 17:56:19 cli[2829]: <341052> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check, 1637: AP class not match, Master-25, Slave-15.
Jun 16 17:56:19 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Image_sync_via_isc
Jun 16 17:56:19 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.240
Jun 16 17:56:20 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6f:38, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
Jun 16 17:56:20 cli[2829]: <341052> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check, 1637: AP class not match, Master-25, Slave-15.
.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.195
Jun 16 17:56:20 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6b:46, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
Jun 16 17:56:20 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Image_sync_via_isc
Jun 16 17:56:20 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.244
Jun 16 17:56:20 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6f:26, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
Jun 16 17:56:20 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.241
Jun 16 17:56:21 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-6c:f3:7f:c3:60:e2, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
Jun 16 17:56:21 cli[2829]: <341052> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check, 1637: AP class not match, Master-25, Slave-15.
Jun 16 17:56:21 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Image_sync_via_isc
Jun 16 17:56:21 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.150
Jun 16 17:56:23 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-6c:f3:7f:c3:64:06, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
Jun 16 17:56:23 cli[2829]: <341052> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check, 1637: AP class not match, Master-25, Slave-15.
Jun 16 17:56:23 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Image_sync_via_isc
Jun 16 17:56:23 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.225
Jun 16 17:56:50 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-6c:f3:7f:c3:61:08, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
Jun 16 17:56:50 cli[2829]: <341052> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check, 1637: AP class not match, Master-25, Slave-15.
Jun 16 17:56:50 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Image_sync_via_isc
Jun 16 17:56:50 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.250
Jun 16 17:56:58 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Isc_send_request
Jun 16 17:56:58 cli[2829]: <341005> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| APAS provision failed, code: connection-failed
Jun 16 18:01:55 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c3:bb:94, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
Jun 16 18:01:55 cli[2829]: <341052> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check, 1637: AP class not match, Master-25, Slave-15.
Jun 16 18:01:55 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Image_sync_via_isc
Jun 16 18:01:55 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.222
LCHS-NTN-25#
