IAP 225 Blacklisting not Functioning
  • 1.  IAP 225 Blacklisting not Functioning
    Posted Nov 16, 2015 01:13 PM
    I have manually blacklisted 52 clients based on their mac addresses. The same clients keep appearing on my virtual controller.
    Blacklisting is enabled on the SSID in question.
    #AP225
  • 2.  RE: IAP 225 Blacklisting not Functioning
    Posted Nov 16, 2015 02:17 PM
    What version of Instant  Code is this?
  • 3.  RE: IAP 225 Blacklisting not Functioning
    Posted Nov 16, 2015 02:44 PM
    Name:
    Aruba Operating System Software
    Type:
    225
    Build Time:
    2014-09-17 07:10:58 PDT
    Version:
    6.4.2.0-4.1.1.0_46028
  • 4.  RE: IAP 225 Blacklisting not Functioning
    Posted Nov 16, 2015 02:46 PM
    Please upgrade to 4.1.1.8 or later and try again.  If you are having problems obtaining that software, please PM me...
  • 5.  RE: IAP 225 Blacklisting not Functioning
    Posted Nov 16, 2015 03:10 PM
    Im upgrading now, will post results in AM. Thanks.
  • 6.  RE: IAP 225 Blacklisting not Functioning
    Posted Nov 17, 2015 08:58 AM
    It looks as if the upgrade worked!
    Although, i have mutliple instances of the blacklisted items showing as a fault on my controller. Is this normal?
    2015/11/16 15:05:20 27 xx:xx:xx:xx:xx:xx Station xx:xx:xx:xx:xx:xx is black listed because 1.
  • 7.  RE: IAP 225 Blacklisting not Functioning
    Posted Nov 17, 2015 01:13 PM
    Normal, yes.  Glad it works.
