IAP 275 DHCP L2 ISSUE
Hi and happy New Year.
I have a small cluster of 3 IAP 275, i use only the native VLAN 1 , and I use the following config
  • Virtual controller IP : 10.10.29.254/24
  • IAP 1 : 10.10.29.253/24
  • IAP 2: 10.10.29.252/24
  • IAP 3: 10.10.29.251/24
I was using the Local layer 2 mode, but when configured I got an error message “that I do not remember”
  • What can be the issue.
  • I noticed that I cannot do a dhcp reservation of more than one IP address , have I missed something.
Thank you in advance
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Valued Contributor II
Re: IAP 275 DHCP L2 ISSUE
Hi Friend,
To understand your issue more clearly, please provide the following information,
1. Are you using a IAP-VPN with the controller ?
2. What is the IAP and controller code you are using ?
3. Why do you want DHCP reservation ?
Please clarify the above.
Cheers,
Venu Puduchery,
