IAP 275 Mesh With the firmware 6.4.3.1
Dear All, i have try the mesh with IAP 275 using the Firmware version 6.4.3.1 , but it was not working at all , have any one of you tray it before. Regards
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: IAP 275 Mesh With the firmware 6.4.3.1
Did you disable 'extended SSID' and reboot the cluster? How did you set up the mesh points?
Yan Liu
Director of Product Management, Instant APs
US Mobile: +1 650 996 3520
China Mobile: +86 136 2121 6844
[http://www.arubanetworks.com/images/aruba-hp-signature-1_130x80.jpg]
Need clarification if you are using Instant OS or Aruba OS?
Jerrod Howard
Dear,
I'm using the IAP version 6.4.3.1 , it is  supposed that it support the mesh.
what is the relation between Extended SSID and mesh , do i have to disable it ?!
Regards
Raouf CHAHBOUNE
thank's folks , i have resolve the problem.
by default the extended SSID is enable , by disabling it   the mesh works correctly.
Regards
Raouf CHAHBOUNE
