Contributor I
IAP 275 - power requirement, is POE 30Watt enough?
Hi ,
I am planning to install IAP 275 outdoor AP. A dell N 2024P swicth with POE output of 30.8 watts be able to bring the IAP 275 up?
I will connect 18 IAP 275 to this 24 port POE switch, will there be any issues?
Or Do i need to order external power supply for these IAP 275?
Thanks in Advance for the help.
Super Contributor I
Re: IAP 275 - power requirement, is POE 30Watt enough?
http://i.dell.com/sites/doccontent/shared-content/data-sheets/en/Documents/Dell_Networking_N2000_Series_SpecSheet_EN_1_0.pdf
The switch appears to be 802.3at compliant which means the AP-270 series will work properly with the switch. Be sure to enable LLDP as its used to negotiate power.
ACDX #419 | ACMP |
Contributor I
Thank you for the reply.
appreciated.
According to the datasheet , your switch has the ability to supply your 18 AP.
It is very important to pay attention to the Switch power Budget , sometimes even when the switch is 802.3at, it does not have enough energy to power all the terminals
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
