Hello. We are currently testing a link redundancy on instant IAP-325. We configured HP 2530 PoE switch with LACP on ethernet 5 and 6. We connected IAP-325's eth0 and eth1 to the switch. We verified that only 1 port on the switch consumes power while the other member of LAG has no power which obviously means that when disconnecting the port that has a power will power down the access point. On the other hand, if we disconnect eth1 port of the access point that has no power would mean the AP will still continue to operate. Is this really the behavior of IAP-325 having the two ethernet ports? Do we have a resolution for this LACP setup?
