IAP-325 with IAP-105 Airwave managed same cluster
Hello, I have a network of IAP-105 running with AirWave management enabled. They want to add some IAP-325 in the same cluster. I know that they have to run the same firmware but I could not find the necessary firmware on the SSO site.
Can you provide the firmware revision please ?
Do you see any drawback mixing IAP-325 with IAP-105 and Airwave config enabled ?
Thank you
Re: IAP-325 with IAP-105 Airwave managed same cluster
IAP-320s are not yet publicly available. Please contact your local Aruba team.
Tim Cappalli | Aruba Security
The IAP 320s are already released?
