Contributor II
IAP 6.3.1.2-4.0.0.2 and Manual Blacklisting
Anyone else had issues getting this to work? We have blacklisted several client devices that are exceeding acceptable daily bandwidths and yet they are still connected and working. We have migrated from 6.2.1.0-3.3.0.3 to the latest code and rebooted to no effect.
Regards
Mike
Super Contributor II
Re: IAP 6.3.1.2-4.0.0.2 and Manual Blacklisting
Check out the black listing time
(Instant Access Point)# show blacklist-client config
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
Can you send the output of ?show tech-support??
Contributor II
As requested have attached a show tech.
Regards
Mike
Contributor II
Have you had chance to look at the tech support file yet?
Regards
Mike
Are you having trouble with the blacklist function on all the configured SSIDs or just some of them?
Contributor II
Good morning - manula blacklist doesnt seem to work on at least the last 3 versions of firmware in any SSID we configure - the device configured on the blacklist is not blocked from the SSID and uses the service as per normal.
Regards
Mike
The current ?show tech-support? does not appear to have captured the time when the blacklisted clients are connecting. Could we black list a test client, connect the test client, and then take the ?show tech-support? dump?
Contributor II
It was captured when one of the blacklisted clients was connected and working.
blacklist-client 2c:d0:5a:9f:8b:aa
blacklist-client 24:fd:52:b0:6e:45
blacklist-client e0:06:e6:81:76:55
blacklist-client 70:56:81:8a:de:77
blacklist-client 54:e4:3a:23:5d:6e
blacklist-client 38:aa:3c:ea:fc:95
24:fd:52:b0:6e:45  Chadwick
Sorry I wasn?t clear. Could we get the ?tech-support? capture from the AP named "199109-AP05-Restaurant", where the Chadwick client is connecting from?
24:fd:52:b0:6e:45 Chadwick 10.113.55.73 O2 Wifi 199109-AP05-Restaurant
Yan
