Regular Contributor I
IAP 92 is not showing on a virtual controller solution of 103 ?
Dear All,
I have deployed virtual controller based soultion at different customer sites.
Customer 1: IAP model 104 solution containing more than 40 IAP.
Customer 2 : IAP model 103 solution containing more than 40 IAP.
Customer 3 : IAP model 103 solution containing more than 50 IAP.
Recently I have deployed virtual controller solution of IAP 103 (15 IAPs) at the customer site. Customer also wants to make the IAP-92 (3 iaps) to be a part of virtual controller solution. When  I connect iap-92 aps, on the virtual controller total 16 accesss points are shown 15 (103) and one (92). The remaining two IAP-92 are properly power up/stable but not showing on the virtual controller. When I power off the two iaps of model 103 then the remaining two IAP-92 which were not showing previously are now showing on the controller.
What should i do to put all the iaps on the virtual controller?
How much IAPs are supported on the virtual controller? Are they should be of same model ??
Re: IAP 92 is not showing on a virtual controller solution of 103 ?
IAP 92/93s cannot be part of a VC that has more than 16 APs.  http://community.arubanetworks.com/t5/Aruba-Instant-Cloud-Wi-Fi/IAP-93-versus-IAP-105/m-p/146306/highlight/true#M4824
Thanks for updating...
Thumbs up
