IAP 93 Can't see Signal Issues.
Im completely new to Aruba. I have installed 9 IAP -93  AP's but can't see the SSID. I do not have it hidden. The network will not show up on Iphone or laptop.  The noise is a little high and the virtual controller says the signal is good but I can't see anything. Any suggestions?
Re: IAP 93 Can't see Signal Issues.
How close are you to the IAP93?  Do you have an ipad (dual band device) to check to see if you can see it?
I wss 3 ft away from it.
Under Maintenence, make sure that you have upgraded to the latest version.  After that, go into the Support Link, change the command to "AP Allowed Channels" and click on RUN to see what channels your APs are broadcasting on:
