IAP-93 Different Bands on differnt APs in same cluster
I have a group of 15 IAP-93. I realize that each AP can only do one band at a time, but is it possible to set some of the IAPs to 5GHZ and others to 2.4 GHZ?
The SSID is set to all bands. I've tried editing the radio configuration of a few APs and setting the 2.4 GHZ band to monitor and the 5GHZ band to access but they always seem to be stuck to the 2.4 GHZ band.. How can I switch it?
I'm on 6.4.2.6-4.1.1.9_51442
