Regular Contributor I
IAP 93 / Mesh ?
quickndirty question : Mesh via IAP93 and then local coverage with 2,4ghz or 5ghz , possible ?
 im not sure, yes they are single-band and normally dual-band is the better choice here to do mesh via 5ghz and local coverage via 2,4ghz .
so what's possible with single band IAP 93 regarding Mesh , im always confused regarding this fact.
regards
ben
Occasional Contributor I
Re: IAP 93 / Mesh ?
IAP 93 will not do mesh.
Re: IAP 93 / Mesh ?
Sorry have to ask again while reading Datasheets of IAP93/AP93 :
Operating Modes
    Secure enterprise mesh
regards
ben
Re: IAP 93 / Mesh ?
Ah it looks like mesh is for inter-IAP communication, nothing more, nothing less, correct ?
so i think the question is answered or ?
regards
Re: IAP 93 / Mesh ?
IAP-92/93 do not support wireless mesh. This features is only supported on IAPs that have two radio that are active at the same time, like IAP-105, IAP-135 and IAP-175.
