Contributor II
IAP 93 point to point wireless bridge
I know that IAP 93 doesn't support mesh links but, our seller tell us that we can configure IAP 93 as a point to point wireless bridge. How can i configure it?, i don't get it working.
Thank you in advance
Re: IAP 93 point to point wireless bridge
Hi,:smileyhappy:
From the userguide:
Mesh service is automatically enabled on 802.11a band for dual-radio IAP only, and this is not configurable.
As far as i aware - you need minimum iAP-105 to start using MESH and use the 802.11a in order to connect backual traffic between units.
Have a lovely night. :smileywink:
Me
Contributor II
Hi, thank for you reply.
I know that IAP93 has no mesh support, but  someone from Aruba tells me that i can configure two IAP92/93 as a wireless bridge, without client service. This is not Aruba mesh, is just a wireless bridge that i need between two buildings
Super Contributor II
did you get any solution for that??
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
Contributor II
Technical support send me a special firmware for doing this.
My experience with this firmware is that is really unestable and you have to use level 3 routing in the last AP of the bridge. For integration purposes this is a nigthmare.
This bridge only works on 2,4Ghz radio.
In my opinion, forget about using IAP 93 for point to point bridge.
Valued Contributor I
Mesh, on Instant, is only supported on our dual-radio models such as the IAP-105, 135, 175.  It is not supported on single-radio like the IAP-93.
**Edit...oops. I just saw that someone else already mentioned that in an earlier post.
